How do I remove a stripped screw accidentally glued to the body?
Hi, I was trying to open up my One M9 but ran across a stripped screw on the top. I've opened the device up before but this time the screw didn't want to give way. I tried using rubber bands, and superglue however neither worked. I think some glue may have gotten on the sides of the screw.
Is there an easy solution to get it out? The screw *was* a torx screw, now it's partly rounded out after much frustration. Could heating up the screw melt the glue enough to the point that I could use iFixit's Screw Extraction set to get it out?
Thank you!
Esta é uma boa pergunta?
