Ir para o conteúdo principal
Home security system with 24/7 surveillance capabilities released 2015. Identified by model number NC1102ES
Why won't the Nest Cam stay on?
I have the camera set up, and the app is working with the camera. However, the camera will not remain on for more than three minutes or so. What am I doing wrong?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
The Nest Cam works best when it is plugged in continuously, ensure that your Nest Cam is in a spot where the power cord can be connected at all times. Refer to our Troubleshooting page for more assistance.
Esta resposta foi útil?
Pontuação 0
Which Nest Cam do you own? I've had a similar problem with Nest Cam Indoor and Arlo Q security cameras. I solved it by contacting the support team. It might help you solve it too.
Pontuação 0
Which one camera you are using? I think it is working now.
Pontuação 0
Adicionar a sua resposta
Lisa Langley será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 1,429
