Ir para o conteúdo principal
iPhone doesn't charge after drop down
Hello everyone!
I dropped down my iPhone 6. The phone had only cracked screen, so I was happy with result because the phone still worked. But! Before I came home, the phone was out of battery, so I plugged it in to the charge but nothing happened after 24 hours in charge. DEAD.
I tried to change battery but still nothing.
When I tried to measure the battery after 24 hours in charge, it had 0V.
I tried to measure input voltage on motherboard and it had only 0.8V and I think that is a problem.
It looks like bad charging dock or something like that. What do you think?
Thank you!
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Thank you guys. I hope that will be the right solution.
por
Adicionar um comentário
2 respostas
Solução escolhida
Definitely the charging port.
Esta resposta foi útil?
Pontuação 2
If the lightning cable doesn't go in fully into the charging port then you'll need to clear it of debris inside the charging port. Something like a toothpick or equivalent will work for cleaning it out.
Pontuação 2
1 comentário:
I think that the problem will be inside charging port. I will buy new one.
por
Adicionar a sua resposta
Milan Rada será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 149
