inverted colors screen in FB
My screen in the Facebook app gets inverted colors when I click on friends pictures. How do I change it? Tried doing it in settings but didn't work. It's only in FB.
Esta é uma boa pergunta?
I would try reinstalling the Facebook app. That's all I can think of that could fix it.
Esta resposta foi útil?
I uninstalled and reinstalled twice. It didn't fix it
Alright. I thought of something else. Restart your phone is one possible fix (not likely but worth trying if you haven't already). The more likely fix is to backup your iPhone, and do a factory restore, next Install Facebook. No other apps. If that fixes the problem, it is some setting, app, or software glitch and it will be tedious trying to get everything the way it was before (you could try restoring your backup and see if it stays working). If it doesn't fix it, then the problem is most likely with your Facebook account settings and you should restore your backup and contact Facebook. Your phone will download all of the apps you had at the point of backup that are not downloaded in your iTunes after restoring from your backup.
Inverted colors in general is a setting within iOS, but it affects everything. Try triple click of home button to switch back and forth from inverted colors to normal colors.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,867
