Ir para o conteúdo principal
Sit-on-top lawn mower. Zero-turn radius mower, 50" mower deck, hydro transmission.
68 Perguntas Visualizar todos
mower starts but will not engage in forward or reverse
My mower will not go forward or in reverse when moving the levers forward or backward. No symptons could be detected prior to the issue. I was mowing and starting to go in reverse and it would not go. At that time it would not go forward either.
Esta é uma boa pergunta?
Pontuação 12
4 comentários
broken drive belt
por
how do you replace it.
por
i had a broken belt spring at the back of my Z-726X that controls going forward and backwards. Easy fix.
por
I have the same problem, under seat i not sure where the tensioner spring hooks to? The frame to pully or some where else. Plz
por
Adicionar um comentário
3 respostas
Solução escolhida
I would replace the drive belt. Instructions will be in your manual. I attached an image of the instructions and the belt routing. The manual is available online at http://www.hammerwall.com/Download_Manua... little bit of an odd site, but it works :-)
Good Luck
Esta resposta foi útil?
Pontuação 4
11 comentários:
Checked belt, it's not broken, what else can it be
por
May Thigpen same mower? Same model? Same problem? what does it do? What have you checked?
por
my wife found a spring under the back of the mower when this happened to us. connection?
por
I am having the same problem the bottom pulley in the back does not turn the upper seems to turn, there was a ringing noise right before it started to act up. JH
por
Jesse Hubbart same mower same setup? What upper and lower pulley? The ones on the drive?
por
Exibir mais 6 comentários
I have a bad boy magnum and I only had it 5days and only 4 running hours on it. My Husband was mowing and went to turn then the mower stopped on him, he started it back up and it came on but he couldn't not go forwards or backwards and it makes this whining noise and doesn't go anywhere. He also noticed that it will only start in the off position on the breaks and won't start in the breaking position.. what happened and how do I fix it?
Pontuação 0
1 comentário:
If it only has 4 hrs on it, take it back to the dealer.
por
Yes Sir .
I have Z5800 Craftsman mower , and I through the drive belt , I put it back on but I can’t figure out the spring connection for tensioner it was hanging down one end was connected to tensioner , I need to know where I connect the of end .
Pontuação 0
Adicionar a sua resposta
Danny será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 90
Últimos 30 dias: 338
Duração total: 99,849
