Ir para o conteúdo principal
Why doesn't my touch's backlight work?
Hi there,
A couple of weeks ago, while I was on the train, the backlight on my touch suddenly stopped working. I tried the backlight settings, but that wasn't the problem. The display was still visible, just only under a strong light. After it originally broke, the backlight seemed to work again when I restarted it. A couple of minutes later, it went again. This process of restarting and then breaking continued for a few minutes, then it stopped working for good. Does anyone have any ideas on what's wrong, and how easy it is to repair? Thanks in advance for your help.
Alex
Esta é uma boa pergunta?
Pontuação -1
2 comentários
my ipod touch has done the same thing and i have came to a conclusion that ipods are crap, next toy ill buy will buy a ipad 3 :D
por
I had the same problem with my ipod touch 2g and assumed that it could be fixed. Unfortunately I replaced the screen and the backlight still doesn't work. Must be a wiring issue...
por
Adicionar um comentário
1 resposta
Solução escolhida
This happened to me too.
My iPod touch 2nd Gen had a broken digitizer but still had an intact screen. The backlight was unaffected and was still very bright. But after replacing the broken digitizer, the backlight didn't come on. I tried shaking the unit, hitting it on my palm, until eventually I gave up. I left the unit ontop my desk, it went into standby with a clear screen, then I woke it up from stanby and the backlight just magically turned on.
The iPod touch from versions 1g to 3g, as of what I have read, have ccfl lamps (a.k.a. a tiny florescent tube light) as a backlight, unlike LED's these things aren't that rugged and can easily be broken by a shock from a sudden jolt, like a really bad fall from your table to a concrete floor.
After reading notes on different forums, I stumbled upon bad news. They said that if your backlight went dead, you'd have to replace the whole LCD, the backlight is fixed on the LCD assmbly and is non replaceable.
Esta resposta foi útil?
Pontuação 1
3 comentários:
Thanks a lot Jem- I think I'll see what I can get for the parts selling it. I think I'm going to go for the new touch anyway.
por
You're welcome! :-)
por
Thanks I m facing the same problem
por
Adicionar a sua resposta
Alex Mulroy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 24,747
