Ir para o conteúdo principal
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
572 Perguntas Visualizar todos
Keyboard cable reconnection: Please help!
Hey, I just followed the teardown for the macbook unibody, the only problem is that I cant seem to reconnect the keyboard cable... What is the best way to get the cable back into its connector???
PLEASE HELP :( its the only thing I have to do to get my Macbook back to life
Esta é uma boa pergunta?
Pontuação -1
1 comentário
Which teardown did you use?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Ok, the common mistake is that everyone seem to reinstall the mid wall that causes problems to reinstall the keyboard ribbon. So remove the mid wall so you'll have a better access to reconnecting the ribbon, it also give you some play room. So once you've done, then reinstall the mid wall and your done. hope that helps. Well good luck with that.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
olaf133 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,328
