I don't know whats going on wit my phone
My keyboard half way working my letters and numbers.. in my top thing when I pull it down in keep coming up and down on its own
My phone is a zte avid plus
Esta é uma boa pergunta?
Start by cleaning the screen then if you have no joy test the touch screen sensitivity does the touch screen work on other apps in all areas of the screen or do you have dead areas. If this is the case the digitizer may be in need of replacement . Has the phone been dropped or exposed to a lot of heat ? Has it got wet ? if so these are all factors in deciding what went wrong
Esta resposta foi útil?
It Ben dropped a couple time but that's about it in sometime I keep it in the bathroom on the charger I listen to music why I'm showering or cleaning but screen not blacking out just my keyboard not type numbers or letters only some in pull down thing keep coming up and down by it self.... I had put it on the charger thenI took it off it starting act like that...so idk it start happen Tuesday afternoon
My friend that stay across from me said that it have to do with something in side the phone he had pull something up on the phone that had lines to check the phone in he said I'm missing a block in the phone cause he did some line thing to check it in when made lines and a spots he couldn't on the screen in keyboard had some not working areas
moisture from humidity of a shower can cause problems there may be corrosion on the connectors to the digitizer. The motherboard may need cleaning. and a drop is never good for a phone . this does sound like a digitizer problem
I'm try to take it to a cell fix place to see can dey fix the problem if not den I need get a new phone
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 2,864
3 comentários
if you can tell use what model ZTE phone you have we may be able to help you
por Jimfixer
Zte avid plus
por Ariel Sankey
I have ZTE Avid 4 and when I get any kind of notification my phone will go off for several minutes before stopping. Now this does not happen every time but several times a day.
por Alexis Estes
