Ir para o conteúdo principal
Repair guides for cameras of the now-discontinued Minolta line.
103 Perguntas Visualizar todos
Minolta X-570: Why can't I advance my film, the lever won't move
One day I shot a picture using my Minolta X-570. The shutter worked normally but when I tried to advance to the next shot, it was if the gears in the camera were locked.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Apparently this is a common problem with the X-570 and the X-370.
When this happens, it means that the shutter mechanism has not fully completed its cycle. This may be due simply to "lack of exercise" - the mechanism may have become a bit sluggish - or a problem with the electronics. Apparently, the electronic circuit that controls the shutter has a part (a capacitor) that tends to fail due to old age. People tell me it's a relatively easy repair, and repair shops familiar with Minolta bodies will fix this problem at moderate cost.
To unblock the mechanism, gently whacking the bottom of the camera against the palm of your hand might help. But it would be a good idea to start looking around for a competent repair shop. Ask veteran photographers (those who grew up using film cameras) for leads.
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
tytypunkin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 21
Últimos 30 dias: 45
Duração total: 5,896
