which external devices are supported by my chromebook c200?
Can I use an external keyboard, mouse and monitor attached to my chromebook?
Esta é uma boa pergunta?
Hi,
According to the specifications there is a HDMI port and 2 USB ports (1 x USB3.0 and 1 x USB2.0) and Bluetooth so you should be able to connect an external monitor to the HDMI port and a mouse and keyboard to the USB ports or the Bluetooth connection. The USB3.0 port is backward compatible so that you can insert (carefully) a USB2.0 plug.
You may find a marginal reduction in battery life with the devices attached so if you also connect the charger you should be good to go.
Perhaps you should look at a using a Bluetooth keyboard, mouse or keyboard mouse combination instead of tying up your USB ports so that they can be used for other devices, e.g a flash drive etc
Hope this is of some help.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 38
