Ir para o conteúdo principal
Repair guides and support for phones manufactured by Jiayu.
Phone dead after connecting wires to wrong pin on micro usb charger
I was in an emergency situation where i needed to charge my smartphone and i only have a broken usb wire and a mirco usb conncetor. I connected the positive and negitive wires to the pins on microusb connector. it worked fine for a few seconds but unluckily the positive wire slipped and connected to one of data pins. The phone turned off. Now as soon as i insert the battery the phone blinks every time i press power buttton and led light turns on or blink in 2 different colors.
I need to ask what parts could possibly be damaged or how can i check the damaged part as i cant sent it back to china to repair and prefer to order the damaged part instead.?
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
@mtk there is not a particular part that will have failed. Any of the components along the dateline that got powered may have failed. Unless you disassemble your phone, have a schematic and a board layout, there really is no way to fix it.
Esta resposta foi útil?
Pontuação 3
if i change the power acpi or motherboard can it be useful in the same case
Pontuação 0
Adicionar a sua resposta
Muhammad Tehseen Khalid será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 21
Ao todo: 878
