Ir para o conteúdo principal
The Vtech Learning Tunes Karaoke is a learning toy for toddlers 3 years and up.
2 Perguntas Visualizar todos
Why won't the mode selector move?
I cannot switch between songs because the mode selector will not move. What can I do to fix this?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
It is possible that the slider is broken or something inside the machine is preventing it from moving. Make sure to keep the slider and the track clean. If it still won’t budge, you may have to open the machine to see if something is stuck inside it. If nothing is blocking the track, the slider may be broken physically. In this case, check out our Mode Selector Replacement guide to address the problem.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Gamuchirai Chifamba será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 60
