Ir para o conteúdo principal
The third iteration of Lenovo's Yoga line of notebooks, similar in design and hardware to its predecessors. Designated by model number 80HE000DUS.
21 Perguntas Visualizar todos
After screen replacement, brightness cannot be changed to save power
After replacing the LCD en digitizer screen on my Lenovo Yoga Pro 1370, the power saver does not adjust the brightness anymore. The brightness control in Windows 10 is also greyed out so I cannot adjust in manually either. I have reinstalled the drivers but this hasn't resolved the issue. Does anybody know what could be the issue?
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Solução escolhida
Hi,
Can you try a system restore to just before you replaced the screen and see if your brightness controls work again? Alternatively here is a link which allows you to run diagnostics on your laptop. Click on diagnostics. http://support.lenovo.com/au/en/products...
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Antony Hulshoff será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 21
Duração total: 903
