The display cover is coming off on the bottom left corner
The aluminum cover is coming off on the bottom left side (when facing the open display) if I pull it gently it separates almost all the way up the left side. I saw similar mentions on 15" MBP and they mentioned glue had come loose. I don't see where is was glued. Ifixit only shows replacing the entire display assembly so I don't know how this was assembled.
Here are some pictures to help visualize the issue.
Esta é uma boa pergunta?
2 comentários
Can you post a couple of good resolution pictures taken from different angles?
por Rany
Orginal post updated with pictures.
por Paul Tiemann
