My headphone jack is very lose
hi
recently the headphone port on my macbook has become very lose and the headphones will easily come out.
my questions is there an easy way to fix this or is it remove and replace the jack
Esta é uma boa pergunta?
hi
Sadly this is not an easy fix :-(
The socket is mounted on the logic board and you'll need to fully remove it to even have a chance of replacing it. This is a job for someone with microsodering skills and the needed parts.
Frankly, I would look for a USB DAC unit as the cheaper way around this. Here's one example: AudioEngine D3
The last option here is to replace the logic board.
Esta resposta foi útil?
ok thanks
will keep using it until its unusable
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 69
