Ir para o conteúdo principal
Released on June 23, 1996, Model NUS-001, 64-bit gaming console
114 Perguntas Visualizar todos
No video- not cable or connections.
So, not the common (cable) video issue with an NTSC version-
With all my games I have audio, but no video. The TV screen will go black when the unit is powered on and I get the audio from the game booting up. I know the cable is fine because it works on my buddy's Game Cube.
I've opened the unit up and used a point file (didn't have any isopropyl laying around at the time) on all the contacts- expansion pack, game slot, power connector and a/v connector. Also done the same with the contacts on the expansion pack and a few of the games.
just kinda wondering what my next steps are...
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
4 respostas
Solução escolhida
You can try a stepwise protocol, its worked for me in the past for reasons unknown. First, take everything out: controllers, game, and jumper/expansion pack. Power it on for about 10 seconds and turn off. Add the jumper/expansion and turn on for about 10 seconds. Then add the game and power on for 10 seconds, then try to actually play something. For some reason its worked for me in the past, but I had both video and audio issues. Worth a shot.
Esta resposta foi útil?
Pontuação 5
5 comentários:
I was having the same problem... BWest you saved me!
por
This worked for me too. I had no signal whatsoever, performed these steps and it worked perfectly. Thank you so much BWest.
por
I had the same issue and your solution fixed it. Amazing. Thanks
por
It sucks. It chucked it as hard as I could and it actually worked
por
I had a unti that powered on but no video/audio. After removing jumper pack and running it for 10 seconds and reinserting it it worked but after turning off and on again the error came back.
It's a temporary solution and takes only few seconds but would still like to know what to do to permanently fix the issue.
por
This worked for me as well..Thank you for the post..!!
Pontuação 1
I had a weird black+white only issue and this fixed it! Thank you!
Pontuação 0
It turns out that following bwests steps, you fry the cpu on the unit
Pontuação 0
Adicionar a sua resposta
Wombler será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 24
Últimos 30 dias: 62
Duração total: 22,333
