Ir para o conteúdo principal
A basic battery-powered rotary tool Manufactured in 2007 by Dremel.
4 Perguntas Visualizar todos
What does the blinking light mean?
I noticed that the green light is blinking. Is something wrong with the Dremel?
Esta é uma boa pergunta?
Pontuação 3
1 comentário
What if it never stops blinking??
por
Adicionar um comentário
2 respostas
Solução escolhida
Don't worry - The blinking doesn't mean that there is an error. The green LED on the charger indicated that you properly plugged the battery pack into it. While it is charging, it will continue blinking. When charging is complete, the light will stay steady green.
Esta resposta foi útil?
Pontuação 11
6 comentários:
Sweet I was wondering the same thing, thank you interwebs.
por
Same here..........
por
Mine keeps on blinking and when I go to use it, it has no power to operate my Mini Mite
por
Mine blinks when I first put the battery in..5 min later its steady green and of course it is NOT charged. Waiting to hear back from Dremel.
por
I have two lighs. one steady red and other is flasing green float. what does float mean
por
Exibir mais 1 comentário
7700/708 battery. green light has been "charging" aka "flashing of 18+ hours and battery is dry as a bone, no charge.
This @#%$#@^ 7700 has LESS than 18 hours of use in 4+ years. Battery is stores away from charger (separate rooms). does the battery just die from being lonely?
Pontuação 0
Adicionar a sua resposta
Kat será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 76
Últimos 30 dias: 379
Duração total: 32,750
