What do I do if my device freezes?
My LG G3 Vigor froze on me while I was using it. It has been frozen now for the past ten minutes, what should I do to fix this?
Esta é uma boa pergunta?
Press and hold the "Power" button and see if the device would turn off. Wait a few seconds and then reset the device by turning the power back on.
Esta resposta foi útil?
Remove the case from your phone and remove the battery. Wait a few seconds,put the battery back in and after you do that, turn your phone on.
Well, I had the same situation and always, I have to do the battery removal and soft re-start. This does not explain why just a simple re-start (On/Off cycle) using power switch does not work. During this freeze, only option is to remove the battery and re-insert and then do a soft restart. Any clues.?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 614
