The Samsung Galaxy Grand looks like a larger S III, or a smaller Note II.
58 Perguntas Ver todas
dropped phone in water now camera doesnt work
I was waking up to answer a text and my phone slipped off my bed and fell into a half full glass of water. I immediately took the phone out and dried it off I took the back piece off and let it air dry cause there was no immediate problems then I get up to use the bathroom I come back and my phone shut down. I turned it back on placed it in rice it turned on fine but now the camera doesn't work and the apps that involve the camera don't work either. what should I do? please help greatly appreciated
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Comentários:
I dropped my phone in my tub of water and the screen immediately filled with water. I fixed that problem for a few nights by letting it air dry but there are still some watermarks in the top left corner that I don't really mind. My problem is that, my camera and any other apps that are provided with camera scripts have all gone black screened and pop up such things as "Warning Camera failed!". I have a Samsung (Galaxy J3 prime.) If anyone has any ideas on how I can fix this, please reply or shoot me an email at tbbrowsbaby1000@gmail.com and I'll make sure to reply with a big thanks!
por
Can you please send it to me too
I have the same problem
por
Basically I dropped my phone in the bath and it was hot water. Everything works fine except the front camera the top of it is white and when I use it it makes pictures blurry. Can I fix this myself?
por
Adicionar um comentário
Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
Visite Nossa Loja
3 Soluções
Solução escolhida
@luna24 couple of things you will have to do. first, skip the rice. It is an absolute myth to use rice. It will not repair your phone, it will not stop corrosion or prevent shortcircuits. You will have to disassemble your phone. Use this guide for some help with that. Then you will have to clean everything with isopropyl alcohol. Remember to remove all EMI shields from your circuit board. Use this guide for some idea on how to clean. It was written for an iPhone but all the points are still pertinent to your phone as well. After a proper cleaning, replace the batter. Then reassemble your phone and re-evaluate. Of course, best course of action would be an ultrasonic cleaning. So if you have that available, use that instead. Until your phone is properly cleaned, it is very difficult to trouble shoot. Remember that water damage is the hardest to diagnose and to repair since virtually any part may have failed.
iPhone Imagem
Guia
Repairing iPhone Liquid Damage
Nível de dificuldade:
Difícil
1 - 2 hours
Samsung Galaxy Grand Glass and Digitizer Imagem
Guia
Samsung Galaxy Grand Glass and Digitizer Replacement
Moderado
20 - 45 minutes
Esta resposta foi útil?
Pontuação 3
I honestly do not know....I came on here for an answer.
Pontuação 0
Mine works on and off after my first cat dropped it in the tub, then after my camera started working a bit my new cat spilled water on it. Rice worked but now my camera works on and off, I can't use it sometimes and I have to wait overnight to use it. I did everything google said. If you have a solution and went through this somewhat please tell me.
Pontuação 0
Adicionar a sua resposta
jesus luna será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 18
Últimos 7 dias: 147
Últimos 30 dias: 554
Todo: 17,706
