Pular para o conteúdo principal
A rugged waterproof portable Bluetooth speaker encased in a smooth grip-like rubber on all sides. Model # PH-BTW55 and released in 2015.
4 Perguntas Ver todas
Why is my speaker not connecting to my phone?
I turned my Photive Hydra speaker on and made sure that my bluetooth on my phone is on. I can't find the device on my bluetooth list from my phone.
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
Kit de Reparo de Bateria do MacBook
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
3 Soluções
Solução escolhida
Hi,
Is there a blue light showing on the bottom right hand corner at the front of the speaker when you switch it on?
If not it means that the battery is flat and needs to be charged. Plug in the charging adapter and see if the light comes on.
If it does let it charge for a while then try to connect to your phone.
If it does not there may be a problem with either the charger, the charging circuit in the speaker or the battery in the speaker.
If it does come on when you switch on is it flashing rapidly or slowly?
Rapidly indicates that it is waiting to be paired. Slowly indicates that it is already paired.
Here is the Ifixit guide to troubleshoot your speaker
Photive Hydra Troubleshooting
Esta resposta foi útil?
Pontuação 3
Comentários:
My speaker is on, (blue light on), my iPhone can’t find the device to connect.
por
The device name should be listed on your phone as PH-BTW55. If it is not listed, try pushing the pairing button on the top of the speaker in between the volume and select track buttons. This enables the pairing mode and the blue LED light will be flashing quickly. Also, make sure you are within the effective distance of the transmitter being 33 feet or 10 meters. If this still does not fix the issue, there may be a problem internally with the Bluetooth transmitter.
Pontuação 0
Did you hold down the bluetooth button on top of your Hydra until the blue lights flash rapidly, then search devices with your phone?
Pontuação 0
Comentários:
I got my speaker 7/6 /18 the blue light be on all the time. When I charge it 20mins later u her a beep to charger. When I turn the music up it not clear sound like how it was a few months ago
por
Adicionar a sua resposta
Matthew Knight será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 32
Últimos 7 dias: 128
Últimos 30 dias: 558
Todo: 17,772
