Stuck in OK to disconnect mode, can't turn on?
I have an IPOD nano and the screen says OK to disconnect with a check mark. When I disconnect it, it seems frozen in this mode and I can't turn it on,off, nothing.
Any answers?
Esta é uma boa pergunta?
Any answers?
hold down the power and vol down buttons till apple sign appears. Worked for my 6th gen with same issue.
Esta resposta foi útil?
Bee Jay, you got it buddy. I did that and my ipod is back , Thanks
thanks , it helped
how smart can one be??? not curing cancer however making sweet music!!
i did that but still doing the samething
It worked! Thanks!
Do a reset. I'm not sure which nano you have, but typically a reset involves sliding the hold switch to hold then back again then pressing the center and menu button simultaneously for 6 to 10 seconds. You may need to repeat this a time or two. Also make sure to be touching only the center and menu buttons, not any other part of the control wheel and push the menu button from only the outer portion of the control wheel, not toward the center. Check out this link to the apple support page where you can select your nano, though the process should be the same:
thank you very much... malama pono ... Aloha 'oi From the Islands of HAWAII
I was at my wits end trying to solve this major issue. Thanks to your clever advise all is back to normal within minutes. THANK YOU!!!!
R Trent.....THANK YOU!! IT WORKED!!
It worked Thanks!!
tnx it worked
Press home and power button
thank you!!
Does not work for my I pod 160
should you keep the i pod in the hold position
thank you it worked
It worked but it said I have to connect to Itunes to restore.
I tried the power & reset button option, the apple logo is visible, after which it goes back to "ok to disconnect" . The local repairer says that it is a hard drive issue. Mine is an iPod black
I connected this to iTunes, but the iPod is not being detected to try a reset. I can hear the hard drive spinning all the while. Any help to resolve this will be much appreciated
Plug your ipod into itunes.
Click on ipod.
Click Restore.
Wait Patiently
Click Sync
All Done!
Step 1.- connect ur ipad nano to pc or laptop
Step 2.- install itune software to ur pc
Step 3.- select ur device (file ---> add device
Step 4.- click restore
Step 5.- follow the instructions
Step 6 .- solved ur problem.
100% its wrkd.. by FB: bala sam Chennai...
Can someone help with my I pod problem, there's a tick in the middle of the screen, reading ok to disconnect, just can't get it off that
i have an ipod quite old and it has a message with tick saying ok to disconnect and it won’t charge i have read others with the same problem but it won’t work please help
Últimas 24 horas: 4
Últimos 7 dias: 23
Últimos 30 dias: 118
Ao todo: 77,091
2 comentários
por sajidrog
@sajidrog me too
por Masha Katsnelson
