Battery Indicator Button Not Working
Hi there!
The battery indicator button doesn't seem to be working. It lights up when I connect the charger, but the lights doesn't come on when I press the button. I recently swapped out my old battery (which couldn't even hold a charge for 3 minutes!) with a Newertech, so it's not the battery. Also, seeing as it lights up when charger is connected, it's not the logic board connector. I have reset SMC and PRAM several times and it doesn't do anything. As far as I've researched, it might be the foam surrounding the button, but I'm also looking for alternative answers as to why it's malfunctioning. If the button itself turns out to be broken, is there a way to buy a new battery indicator?
Please and thank you's!
Update (02/24/2016)
I opened it up and found that everything was in working order. It seems to me that it is the button itself that isn't working, whilst the LED's work as they should. I'm attaching a picture of the unit, if that could be of any help at all.
Esta é uma boa pergunta?
