How to get LCD to stick to frame?
So I cracked my screen, I ordered a new one, removed the old screen, cleaned the frame of the old adhesive, then I used some red vhb adhesive tape around the frame, installed my new screen, pressed down/held it down for about 1-2min. Then started using it for about 10-20 min. After about 15min the middle part of the frame (on the sides) started lifting up substantially. How can I fix this? Did I use the wrong adhesive? I didn't go for the pre-cut adhesive because i've heard it is not sticky at all and others were having problems with the lcd lifting from the frame. So I decided to use the red vhb (very high bond) adhesive. Did i do something wrong? am I supposed to heat up the adhesive with a heatgun/hair dryer to make it stickier, and then apply the LCD?
Please help.
Esta é uma boa pergunta?
