Camera won't switch to different lighting settings
I brought my instax mini eight out for the first time to take a couple pictures on a hike, and when I went to adjust the lighting from indoor to cloudy, it didn't change. The orange light switched between all of the settings without me turning the dial, and eventually became stuck on the indoor setting. Can the camera be fixed?
Esta é uma boa pergunta?
5 comentários
umm what if the lighting setting/the adjustment for the lights does not flash
por rebekah
My film wont came out and the censor light wont turn down even when i shut the camera down, how can i fixed it ? :(
por Mamamia
my light doesnt change to any of the icons it just stays on "home" icon, I JUST GOT IT OUT OF THE BOX
por angela fields
My problem is that, all of the icons are all lighted? How can I fix this? Please I badly need help. Thank you
por Ella Mae Siva
I had the same problem! It may be just a mechanical problem but if you look closely at the lense, you will see that it still opens and closes with each dial turned. The orange light is just showing what its on but with that broken, the whole thing still works. The lense with the biggest opening brings the most sunlight and the smallest opening is the darkest setting. Hope this helped!
por jinramen
