Hi @shirlyboli27315 ,
Can you make outgoing calls OK from the phone?
Have you tried adjusting the base unit ringer volume to see it it rings OK? To do this, on the base station, press ↑ key repeatedly to select the desired volume. Pressing and holding the ↓ key and waiting until it beeps, turns the ringer in the base station off
What signal do you hear when you call your landline phone number from another phone e.g. mobile phone? A ringtone signal, a busy signal or nothing at all?
If you hear a ringtone signal disconnect the base station line cable from the telephone cable socket in the premises and then call the number again.
When you hear a ringtone signal in the calling phone, short out the two wires in the telephone cable socket with a screwdriver or a pair of scissors etc and check if the ringtone signal that you are hearing in the phone you are calling from stops.
If it does then there may be a problem with the base station cable that connects to the telephone cable socket or in the base station itself.
If it doesn't stop then contact your landline service provider about the problem as there may be a problem with the telephone cable or in the telephone exchange.
If you hear a busy signal or there is no signal at all, disconnect the base station from the telephone line socket in the premises and then call the number again and check what signal you hear.
If you hear a busy signal or no signal at all contact your landline service provider about the problem.
3 comentários
I seem to have a double ring tone on my Panasonic cordless phone, the default and the melody I selected. I want to keep the selected melidy
por irene.raletich
I have a five phone system. When an incoming call comes, only three of the phones ring. What can I do to make the other two ring. It is a Panasonic KXTG270.
por Patti Fishel
I had this problem just now, turned out to be one of the wires to the speaker was disconnected, a bit of solder and new pieces f wire sorted it.
por Phil S
