Problem with iPad 3
Hi
I've got some problems with my broken iPad 3. It was waterdamaged and now the touchscreen does not work. I also tried another digitizer (tested on another iPad and was working fine), but no success.
Also I noticed that when I start up the iPad the clock shows january 1st 1:00 (due to disconnection of battery), but the weird thing is, that it continues until 1:05 or 1:06 and then jumps back to 1:00 without restarting the iPad!
The LCD, the Digitizer, the Battery, everything was taken from a working iPad to test, so I think that the issue must be on the logic board.
I did clean and visually inspect the logic board without success.
Does anyone have an idea what could be defective?? Or where should I check? I do have the schematics available but have no idea where to look.
Thank you very much for any help you can provide.
Also, is it possible to make a backup on an unknown computer without confirming the computer on the iPad (since I can not input the passkey I don't know how)
Update (02/18/2016)
Does nobody has an idea for me?
Esta é uma boa pergunta?
it does seem as if a logic board error
what did you clean it with?
can you upload a picture of the logic board?
about the back up
i am not 100% but from what i can remember when i damaged my iPad i used iexplorer.
por Alex Hus
Hi! Thanks for your response. I did clean it in an ultrasonic bath with special cleaning solution and afterwards I rinsed it in Propanol.
I could upload a picture of the logicboard, but it looks perfectly fine. Do you need a special part of the logicboard?
por Chebno
The picture was just to see f there was any damage
but if you are happy that it is clean then no image needed
i suggest doing a visual check around the battery connector
i can't really think of anything
first time I've hear of the clock resting
por Alex Hus
That is the weird thing! The clock just resetting. Battrery connector looks fine. Also the iPad boots up so no short there....
Could it be that the problem lies within an IC? Maybe the Digitizer Control IC from Texas Instruments?
por Chebno
wow
i don't know I'm baffled
im not sure which schematics you have but heres the apple one https://yadi.sk/d/6282hMsccQ5PT (better downloaded)
por Alex Hus
Exibir mais 6 comentários
