Ir para o conteúdo principal
Released June 2014, identified by model number B051.
beats rights side stopped working
The right side of my beats randomly stopped working and I need to fix them
Esta é uma boa pergunta?
Pontuação 14
2 comentários
A repair for the right side would be so greatly appreciated.
por
99% of the time this occurs with the solo 2 model, it is due to a torn internal wire. Check out Joesge.com to get your headphones repaired for a reasonable price. As simple as filling out a service sheet with steps to get them shipped in.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
After doing much research about this. I too have the same problem and found out that the wires on the right side are more vulnerable to getting pinched and freyed due to lack of protection unlike the left side. You can repair it on your own by re saudering the wire to the connector or calling an electronics store to see if they fix headphones. If you need help fixing it yourself look up helpful videos on YouTube. Good luck!
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Dylan hammknd será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 31
Ao todo: 13,435
