Ir para o conteúdo principal
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
211 Perguntas Visualizar todos
water leaking in the back of the wash machine
When the water runs in the washing machine it leaks in the back what would that be
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
There are two hoses that run from the inlet valves (faucets) to the washing machine. Check to see where the leak is coming from, probably with at the valve or where they hook up to the washer. Could be just old washers.
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
Catherine Campbell será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 391
