Ir para o conteúdo principal
The iRobot Roomba 560, an automated vacuum cleaner, was released in 2009.
14 Perguntas Visualizar todos
Access to Roomba 560 circuit board.
I have a faulty Roomba 560. afer substitution teting I gather the problem is in the board.
I suspect the problem may be in some capacitor as the problem is intermitent but recurring.
simple screw driver dismantling left me short of the pcb.
Where can I find instructions to access the pcb?
Esta é uma boa pergunta?
Pontuação 1
2 comentários
Did you try to find solution from irobot customer care? I think you should not fix roomba by yourself, it's still a high tech machine anyway
por
Oh, try to find answers form other sites like http://irobotroombareviews.com/ I've just catched it last week and it's quite useful
por
Adicionar um comentário
3 respostas
Solução escolhida
Hi, Here's a link to the service manual. Hope it helps.
http://choisirsonaspirateur.info/wp-cont...
Esta resposta foi útil?
Pontuação 3
2 comentários:
+ research
por
Thanks, most useful info
por
Pergunta mais útil
I had a similar problem, but had to replace some sensors on the board. Looked all over for a fix. Found an affordable one that worked well. took an hour or so.
http://eesolutions.ca/roomba_repair_kit....
I'd recommend it. Took forever to find the site though.
Pontuação 5
Hi.
Here is quick fix for your roomba.
http://www.abstractpath.com/2008/fixing-...
Cheers
Pontuação 0
Adicionar a sua resposta
Axel Brinck será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 13,282
