Ir para o conteúdo principal
Segunda de sua geração, lançada em novembro de 2011, a Sony SLT Alpha-65V é uma câmera SLT (tecnologia de espelho translúcido) com montagem de lente Sony Alpha/Minolta.
SD card can't be inserted
Hi guys,
I think I have ruined my camera SD card slot, the SD-card can't be inserted , when I push it into the slot, it return back without getting in place. even I can't hear any click to let me know that the SD card is in place.
How can I repair this? do I need a new spare parts? any reference parts number?
Thanks a lot
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Did you try inserting it the other way? It will only fit in one way.
Esta resposta foi útil?
Pontuação 0
Check the slot with another card...it could be a small part of the card has broken off...never force a card into a slot...if it still won't click home...worse case scenario...use a flashlight and look into the gap of the card holder to see if the metal tongues are misaligned...If they are bent out if shape...then you can try Luton Cameras for spares....they usually supply for canon and Olympus but sometimes keep Minolta Sony bits or will direct you to another source...lastly go to eBay and see if you can source a spare and repair Sony Alpha...
I think most Minolta models use the same module for card slot holders.
Pontuação 0
Adicionar a sua resposta
mhamdani será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 27
Ao todo: 1,098
