battery will not charge.
i have a g 4 the power cord was tripped over and pulled and the charging receptor in the computer may have been damaged. battery will not charge
want to open computer and fix.
Esta é uma boa pergunta?
The most likely problem is your DC-IN port. We need to know the Exact model you have to direct you to the correct part and repair manual. Remove the battery and look in the compartment as most Books have this information in there.
Esta resposta foi útil?
thanks for reply/serial yd6050baswz/ refurb BPg4 15/1.67.1x512/80/sd-dl/apx/at- usa
Here's the part: [produto vinculado ausente ou desativado: IF154-108]
Here's how to install it: ere's how to install it: PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement
all procedures followed and ok until the last. the rj11 cable and square piece is not on replacement part! there is just a space on replacement part. what do i do next? does taht piece get rmoved from old part and attached to new? or is part wrong?
no worries i fixed it. its working!! thanks very much/ doug
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,012
2 comentários
awesome ! thanks for the help and info. will let you know how it goes.
d
por doug
hello/ please see my latest comment from today. something different in replacement part? computer apart. waiting for help?
por doug
