Can I use iPhone 4s battery in iPhone 4?
I have an iPhone 4 with a dead battery. And an iPhone 4s with a flaky charging port. Can I put 4s's battery in the iPhone 4? Would it work as expected?
Esta é uma boa pergunta?
The simple answer is no.
They use different connectors. :-)
Esta resposta foi útil?
Ah, good to know! So, to clarify by connectors do you mean charging ports? Or something else?
All the parts between the iPhone 4 and 4S are different, the only thing that is the same, is the LCD and digitizer connector, but the frame on the screen is different.
And I mean connector as in the connector on the battery and on the logic board.
Appreciate your detailed response Ged!
No problem! :-)
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 101
