Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
604 Perguntas Visualizar todos
Is battery from 2015 MBA the same as the MBA 2011
Hi!
Do you know if battery from MacBook Air 13" 2015 will work in a MacBook Air 13" 2011?
Esta pergunta é pertinente?
Pontuação -1
1 dos comentários
Is your current battery dead or in need of being replaced? If not are you expecting the newer battery will give you more run time on battery?
por
Adicionar um comentário
1 Resposta
Solução escolhida
No. These batteries are not interchangeable. They are shaped differently (close, but not close enough to work), and they have different logic board connex.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
crownvu será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 98
