Ir para o conteúdo principal
The Nintendo DS is Nintendo's seventh generation handheld game console and is the first of its kind across all systems with dual-screen technology and use, apart from clamshell Game & Watch systems.
Why aren't the L&R buttons working?
I have an original DS. No Mods or anything ever done to it. The hinge is slightly damaged, but I doubt that's related. For some reason the L & R buttons are not responsive. On a rare occasion, one will work, but usually they don't.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
This has happened to me with every model of DS I've owned and if it's like my problem it's just dust stuck under the shoulder buttons. I can usually get by with just blowing air under the L and R buttons. Replacement shoulder switches are available from some other websites but you have to solder. If you want to do that you should be able to just follow the steps in the back panel removal guide to access them. Then remove and replace.
Esta resposta foi útil?
Pontuação 4
1 comentário:
+ nice clear answer
por
Adicionar a sua resposta
Jacob Sharf será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 9
Ao todo: 4,393
