How to change shielded Wire
My shielded wire is broken,how to change it?
Esta é uma boa pergunta?
This is a big job so make sure your upto it.
First you'll need to remove the lid assembly. Follow this IFIXIT guide: MacBook Pro 15" Unibody Early 2011 Display Replacement. Once you have taken the display fully off jump to this guide MacBook Pro 15" Unibody Late 2008 and Early 2009 AirPort/iSight Cable Replacement. Here we want to jump down to Step 25 to see how the Clutch cover is fitted. You shouldn't need to pull the glass off to remove the cover alone. Most techs just replace the full assembly as taking the glass off is not easy and often leaves a messy edge.
Guia
Nível de dificuldade:
Difícil
45 minutes - 3 hours
Guia
Muito difícil
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 35
2 comentários
Are you talking about the antenna lead from the lid?
por Dan
how to open the black space under the screen
por Cheng Tobin
