Ethernet on but, not working
Hi, This started with a spill (coke I think) I opened it up (this unit sat for about two years before I received it) and seen drops of coke on the optic drive, two drops on the cooling fan. I looked at the board I could not see anything on it. I opened the optic drive did not see any coke drops or stains of coke. I removed and cleaned the keyboard for sticky keys it now is working. Started it up and optic drive spun up went to the install long story short here could not find the hard drive. removed old hard drive installed a new one started back up hard drive found loaded o/s. connected to the internet via cable connection for updates will not go to the internet. went to system preferences/network it says currently active and has a green light then I went to network utility under network interface (enO) states link status Active, link speed 100Mb, it has a IP address yet I can still not get to the internet and I the internet/line cables are all ok because I checked with another computer and I can get to the internet with it.what is going on?
Esta é uma boa pergunta?
4 comentários
What is the ip address? Is it one that your router/isp gives out via dhcp, or is it one of the ones that OSX automatically? If it's getting dhcp from the router then you will know that your hardware is fine.
por BigO
Have you plugged that exact same cable into another box to verify that the cable works? Have you checked the security settings on the router to see if it's filtering by mac address and not letting your machine connect out?
por BigO
BigO
I clicked on the "Renew DHCP lease" button (in system preferences - network) I'm not sure but I guess that's from the ISP.
I have my computer and I used that cable to connect the macbook and when the macbook would not go to the internet I hooked it back into my iMac no troubles it went to the internet.
Thank you for your interest in helping me with this.
por prostreet360
I went to our local library and was able to use airport so, I down loaded up-dates returned home plugged it in and clicked on safari it went to the internet via ethernet it was on for awhile and it went out then later it returned and now back out.
por prostreet360
