Touch ID Button glass cracked - repair w/o loosing fingerprint feature
Is there a way to just replace the glass on the home button? The Touch ID sensor does not work due to the cracked glass.
Esta é uma boa pergunta?
No it's not possible, the sensor chip is thinner than human hair and extremely brittle. To make the matter worse, the chip is glued to the button crystal so there is no way to remove it without breaking it.
Esta resposta foi útil?
Thanks because I knew it could be repaired on iPhone 8+ but I was thinking because in my case with cracked button glass I was Not able too repair touch id.
you are always right n you are here :)
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 440
