Ir para o conteúdo principal
The Acer Aspire One model D225E is a 10.1-inch netbook that features an ultra-thin and lightweight design with a powerful battery making it ideal for everyday computing on the go. Also known as Acer Aspire One D255E-13639.
20 Perguntas Visualizar todos
Pergunta encerrada
Why my netbook screen turns to red?
I have my netbook ACER DC22 DCkk which was I bought a few a years ago. When I opened it the screen turn into red with a frizzy lines of dashes. I don't know what's the problem with my netbook, should I replace my screen with a brand new one? or there is just a problem with the connection inside?.. I need your answer please.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
It sounds like it is a damaged connection of some sort.
If the the screen was the problem, you would have dead pixels or visible cracks in the image.
Look at the hinges of the device, often if they are damaged then that is where your locate the issue
I haven't had the best luck in working on this kinda problem, but anything is repairable if you want to put the effort into it.
Have you tried connecting to an outside display? Then you rule out a software glitch.
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 105
