Is the GPS likely to be damaged by a hit?
I have an Iphone 6, the GPS is not working and I took it to the service, they said the warranty is not valid since it has a hit in the lower-left part of the telephone and the antenna located there is damaged, Is there a GPS antenna really there ? (close to the earphone plug) or Are they trying to fool me?
Esta é uma boa pergunta?
4 comentários
Hi,
Have you tried GPS out in the open, away from under trees and buildings? It may be losing signal. Just a thought.
por jayeff
It could happen.. Is your wifi and Bluetooth working?
por iMedic
Yes, everything is working perfectly. Only GPS is failing, and sometimes works. When I use WAZE or Google maps I don't get accurate location
por Ana
I usually test the GPS while I am driving and many parts of the city, streets, highways etc.
I have restored the IOS because the first time I took it to service they said the problem was about software and they recommeded to restore, I dit it and the issue was still there, I took it again to service and now they said the issue is related to some hit in the lowest-left part of the phone. I don't trust them since they are changing their diagnostics, I want to know if the reason they are giving me can be real or not otherwise I Can contact customer service and complain.
por Ana
