Ir para o conteúdo principal
Repair guides and support for Ematic tablets.
99 Perguntas Visualizar todos
How to reset tablet?
Ematic Eth103 13.3" tablet having problems with progams not working hanging up,
I go to youtube and can not get out of full screen. Deleted some programs tried to upgrade to android 5.1 could not do it. Tried to reset by holding down the power button and the volume up did not work volume down same thing. What can I do.
Esta é uma boa pergunta?
Pontuação 12
13 comentários
unluck tablt how to open
por
I did what you said but it stays on ematic smybol powered by Android
por
Mine is doing this same thing! Did you ever get it to work?
por
Did you fix the problem from that screen?
por
My daughter tablet stop working don't even turn on
por
Exibir mais 8 comentários
Adicionar um comentário
2 respostas
Solução escolhida
Soft Reset
Step 1
Locate the reset button next to the headphone jack on the side of the tablet.
Step 2
Insert a paperclip or another thin object into the hole.
Step 3
Press the reset button with the paperclip to reset the tablet.
Factory Restore
Step 1
Tap "Settings" on the tablet's home screen.
Step 2
Tap "Personal" and "Backup & Reset."
Step 3
Touch "Factory Data Reset" to restore the tablet to its default state.
Esta resposta foi útil?
Pontuação 3
9 comentários:
I have no button....how else?
por
Sheila, it's not right by the headphone jack, just in the nearest vicinity. I did this and still nothing.
por
What if you can 't find the rest button where else do i look?
por
Could you find a way to reset it?
por
The ematic tablit is different to other tablets because it has a physical reset button. Follow my instructions to factory reset your tablet.
Note: This will permenantly delete all data including photos, apps, music and any other information on the device.
Find the reset button it should be a small hole beside the hedphone jack.
Insert a paperclip or other thin object into the hole.
The tablet will reset.
por
Exibir mais 4 comentários
In soft reset - Press power button by holding the power button down for 15 min until you see the logo.
In hard reset - 1. Unplug the device
2. Power off the device by holding power button.
3. Wait 5 seconds, then hold down both the volume up and power buttons.
4. Press the volume up button to move the arrow until it is pointing at the Recovery Mode option, then press the volume down button to select it.
5. The logo should appear for a few seconds, then you should be in the system recovery menu. Use the volume up / down buttons to highlight the factory reset option, then press the power button to select it.
6. Use the volume up / down buttons to highlight the “Yes — delete all user data” option, then press the power button to select it.
7. Once you completed, you should be returned to the system recovery menu. Select reboot system now, then press the power button to select it.
Pontuação 2
4 comentários:
Done all that not working
por
I did everything it said but it is still staying on the start up screen that has the ematic n powered by android hasn't changed since last night
por
That doesn't work either… apparently you don't know anything about how to do it. You just like talking big like you do. Thanks for nothing.
por
@Bre Burton how did you fix the problem my tab is doing the same thing.
por
Adicionar a sua resposta
gabep1 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 61
Duração total: 26,161
