Ir para o conteúdo principal
This product is a 27-inch LED display with a resolution of 2650x1440 pixels released by Apple on July 27, 2010. It has the model number A1316.
78 Perguntas Visualizar todos
Replacing 27" Cinema Display LCD with iMac LCD
I'm trying to replace my 27" Cinema Display's LCD but I'm unsure about compatible panels.
I need LM270WQ1(SD)(B1) but do other panels work too? Like the ones for the 27" iMac?
Btw, it's not the Thunderbolt-version.
Thanks!
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
It will work with the iMac display, but you’ll have to transfer the display board and backlight of the old display. I did it and it works great.
Esta resposta foi útil?
Pontuação 3
3 comentários:
Hi there' I'm interested to know more on how you did this, I have all the relevant parts etc, and have enough skill to try, please could you possibly elaborate more on what you actual did to get it to work, I kindly await reply.
por
but I think I know what you mean.
por
I am interested in this solution... I have good known display boards, but did not understand the backlight part of the answer. Do you mean the LCD function cable, or the actual led strip? Can you elaborate?
from what I can tell, the cable that goes to the led strip has the same connector in the two displays...
por
Adicionar a sua resposta
MacF será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 29
Duração total: 1,840
