Ir para o conteúdo principal
Repair guides and service information for Kenmore Dishwashers
Dishwasher won't start wash cycle
My dishwasher won't start a wash cycle. All of the front panel buttons illuminate. The drain motor starts when the Drain button is pushed, but the Start/Resume button neither illuminates, nor starts the cycle. The first two times that I pulled it out to check connections, it started after pushing it back in place, but now nothing. I've already tried flipping the breaker for a few minutes.
Esta é uma boa pergunta?
Pontuação 3
1 comentário
Clean light is blinking 7 times and DW won’t start
por
Adicionar um comentário
2 respostas
Solução escolhida
Cause 1
Touchpad and Control Panel
First, ensure that the display works. If the dishwasher display is working but the some of the button don’t respond correctly, the touchpad and control panel might need to be replaced. (Some manufacturers sell the touchpad separately from the control panel. Other manufacturers require that you purchase the touchpad and control panel together. If you cannot replace the touchpad individually, replace the touchpad and control panel.)
Cause 2
Touchpad
First, confirm that the dishwasher display is working. If the display is still working, try pressing some of the touchpad buttons. If some of the buttons respond correctly but others don’t, it is likely that the touchpad is at fault. (Some manufacturers sell the touchpad separately from the control panel. Other manufacturers require that you purchase the touchpad and control panel together. If you cannot replace the touchpad individually, replace the touchpad and control panel.)
Cause 3
Main Control Board
The main control board regulates nearly every function in the dishwasher. If there is a problem with the main control board, it might not send voltage to the dishwasher touchpad, causing the touchpad buttons not to work. Control boards are often misdiagnosed; make sure you test more commonly defective parts before replacing the main control board.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Go to your fuse box and turn the power to the dishwasher off for about 10-15 seconds turn back on. This should resolve your problem. Kenmores are notorious for this issue.
por
On some Kenmore dishwashers, hold in the start button until cycle button lights up AND WAIT two minutes before dishwasher starts. The owners manual will explain how to start the dishwasher. If the control panel lights up, more than likely there’s nothing wrong with the dishwasher.
Pontuação 1
1 comentário:
Yooo...you are genius
por
Adicionar a sua resposta
Steve Quinzi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 76
Ao todo: 21,326
