Ir para o conteúdo principal
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 Perguntas Visualizar todos
Why my samsung can't turn on?
my samsung galaxy s5 had only 16% battery left, so i listen to music over 1 night and in the morning my samsung can't turn on, i've charge it for 11 hour but still can't turn on the samsung..WHAT SHOULD I DO ?! HELP!
Update (12/26/2015)
Should i buy a new battery ?
Esta é uma boa pergunta?
Pontuação 1
3 comentários
When you have it plugged in to charge is it showing that its taking a charge or are you just assuming it is. Your problem may be that its not actually charging . Try a different cable or different charger , hook it to your computer and see if you can connect to it
por
thanks a lot
por
so, i've try a different cable ( charger too) and it seem can turn on, but the problem is the screen is tonally black,..what should i do?
por
Adicionar um comentário
2 respostas
Solução escolhida
Possible battery failure, have you tried a known working battery?
Esta resposta foi útil?
Pontuação 1
2 comentários:
what is known working battery?
por
A known working battery, a battery you know that works, like a friends battery.
por
Are you sure you are charge it for 11 hour?
Pontuação 0
2 comentários:
yes
definitely
por
You mean It is can turn on , but the screen is black,
It is possible that the lcd screen is out of work..
por
Adicionar a sua resposta
luciancifer será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 178
