The window was peeling touch the top right of 1mm support
Hello,
I noticed that the window was peeling touch the top right of 1mm support. Is this normal? Is it not a fault fabication ? because the phone is never dropped or shocked and never took the water either. if you have an answer to this problem thank you .
Esta é uma boa pergunta?
1 comentário
[image|729739]on this picture can be seen the front detached from the support. The question is why it comes off . I know it will change the whole front here but I want to understand if other people have the same problem.
Thank you
por bekman
