Error 53. Need help repairing original iPhone 6 home button.
I was wondering if there is anyone out there that can repair my original iphone 6 home button original pin connector by desoldering the connector and soldering on a new one. I read a forum here where someone said that fixed their error 53 for their iphone 6 plus. I hope this solves my issue because I replaced the home button cable flex not once, but with three different new home button cable flexes all assembled and still error 53. My home button still works, but the touch id is not being detected. I believe the connector got damaged and my only solution is desoldering the connector pins of the one I damaged and solder on another one from any working home button pin connector.
Oooops home button cable connector removed / lost! Easy to repair?
Esta é uma boa pergunta?
Have you checked the logic board side?
por Tom Chai
Yes I have checked all of the logic boards connectors and they are all fine. What happened was when I was doing a screen change. I pulled off the home button flex cable with the home button and it got stuck on there. I then used a razor knife to take out the home button flex cable out of the home button. Since then my home button still works, but the touch id isn't and is causing error 53.
por ShuVang
