Ir para o conteúdo principal
Support for gas-powered and electric golf carts, sometimes referred to as golf cars or club cars after the Club Car Golf Cart brand.
493 Perguntas Visualizar todos
My cart won't run
My 92 club car gas cart runs great until u stop then it will not crank back up til it sits while.I changed plug .carb.at a stopping point. Seems like if the coil is getting hot it would die when it got hot but I run it 2 hours non stop and it will not quit.it's when u stop it won't restart.I've rum it 15 min or 2 hours it's the same ether way.any input would be greatly apreciated...
Esta é uma boa pergunta?
Pontuação 2
1 comentário:
Hi Bryan, did you ever find a solution to your golf card. I have the exact same problem now with a CarryAll turf 2 .
Thanks.
por
Adicionar um comentário
2 respostas
I am thinking the starter and maybe the solenoid switch too must get hot. That will not matter as long as it turns fast enough to start. This sounds a little like a vapor lock. Will it start if you remove the air filter? The gas line, does it have a pump and/or a filter. If you were trying to start a partly clodded fuel line. After the fuel line sits fuel would dran to the carburetor and pool in the carburetor. After it starts the suction would keep it running till the engine cuts off and you lose vacuum. Then the line would have to dran fuel past the partial stoppage till it can get enough fuel to the carburetor to start. This is just a guest mine you, but you may want to blow out the fuel line and change any filter then check the pump if any.
Let me know what happen.
Jim
Esta resposta foi útil?
Pontuação 0
1 comentário:
My golf cart just won’t go we fixed the part that need to be fixed I drove out in the woods went up a trail it shut off went back down the hill and now it is just sitting at my house not working we tried jump starting it over and Over again we are going to fix it soon we don’t know what is wrong with it so we got to take it to a shop
por
They not want to start
Pontuação 0
Adicionar a sua resposta
bryan franklin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 6,464
