Pular para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
3009 Perguntas Visualizar todos
iFixit iPhone 4S Replacement Battery Shutdown issues
After using my iPhone 4S for 3 years, its original battery was terrible. It was draining faster than any electronics devices battery. I replaced it with iFixit's battery. After some initial success in battery life, iFixit's battery started behaving the same, with some slight(!) issue. When iFixit's battery in the phone, the phone shuts down sometimes at 25% charge, sometimes at 30%. I can't even make an estimation on when it'll shut down. I don't see any solution to this, so I will switch back to my old battery, but does anybody know why this early shutdown thing happens? Am I the only one who's having this problem?
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
Kits de reparo de android
A new screen or battery is one kit away.
Comprar agora
Comprar agora
3 Soluções
Solução escolhida
Seems like your new battery is faulty. Contact iFixit sales customer service for assistance. Good luck.
Esta resposta foi útil?
Pontuação 1
Dose the phone feel warm?
Could be a failing chip on your phone or a temp sensor
Have you tryed a factory restore?
In sum cases you need to reload a new clean iOS on your phone or tablet to allow the battery to function normally.
Is it possible while installing the battery the ribbon may have been slightly damaged or not fully connected?
Also make sure your power port is clean. Use a clean too the brush and get any gunk out. Hope you find this usefull
Pontuação 1
Hey man
You should replace your iPhone 4, lol
Pontuação 0
Adicionar a sua resposta
furkanakyurek será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 98
