Ir para o conteúdo principal
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
382 Perguntas Visualizar todos
Blacklight, temperature, lcd, screen,
Hi guys
I have a problem with my iMac i7 27" late 2009.
sometimes the screen goes black for no reason. I try to put the flash from my iPhone on the corner of the screen and I can see the icons. Every time that I turn on my iMac after few minutes the screen goes black again. I leave the iMac until stand by and I come back to it after 10 minutes, the screen work again but after few minutes black again. I was thinking there are some problems with temperature sensor or my back light led doesn't work properly. I will insert few pictures from temperature gauge if you would to have a look.
Those picture are about 10 minutes working.
After those one just for the LCD temperature it's grow up in about 10 minutes.
Please let me know and help me to fix this problem.
Esta é uma boa pergunta?
Pontuação 1
3 comentários
When it goes dark can you see the desktop with a flashlight?
por
Yes I can see the desktop with a flashlight. Not really well but I can.
por
Hello Claudio Pili, I have the same problem, What do you do to fix the iMac? Please Healp me. Thanks.
por
Adicionar um comentário
1 resposta
Solução escolhida
Replace the LED Driver board. Here's how: iMac Intel 27" EMC 2390 LED Driver Board Replacement
It replaced the inverter but does the same thing.
Esta resposta foi útil?
Pontuação 1
1 comentário:
ok, I will try to replace the LED driver board. I will come back to let you know.
thanks a lot for the moment. :)
por
Adicionar a sua resposta
Claudio Pili será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 317
