SSD slot on logicboard or not
So on the 2013 model there is an SSD (blade) slot on the logic board even if you ordered the iMac without ssd or fusion.
is that also the case with this 2014 model? can anyone confirm?
pictures on the iFixit manual says its not, but then again this model does not have a teardown to dubble check.
could anyone confirm what the status of the SSD blade socket is on the logicboard?
Esta é uma boa pergunta?
3 comentários
Ok, thanks...
this is the answer i was looking for...
por Stefan
No guys! It is not! I bought iMac 21.5 Mid 2014, i5 1.4Ghz, intel hd 5000, 500gb hdd, and I can confirm there is no Pcie slot! I do not know how to check logic board model on terminal, maybe there is some with slot?
por juliusgoncarukas
juliusgoncarukas - I stand corrected!
Yes, this is one that if bought with a solo HD does not have the SSD blade hardware populated on the logic board. It also has soldered RAM
iMac 21.5" 1.4 GHz i5" (Mid-2014)
por Dan
