Ir para o conteúdo principal
Pleo is an animatronic dinosaur toy designed to emulate the appearance and behavior of a week-old baby Camarasaurus.
How do I fix a split in Pleo's neck?
My pleo has developed a split in his neck. How can I fix it?
Update
my pleo hasnt got a broken neck its his skin that has split. i was wondering if there was a way of repairing him
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Please post a picture so that we can see what you're talking about.
por
Adicionar um comentário
4 respostas
Pergunta mais útil
Well, If you could get to the underside of the skin, you could do something like a bicycle tube repair (You could do this from the outside, but you would get an ugly patch on the outside of Pleo). I would use contact cement, and a piece of rubber as a patch. You can get contact cement at your local hardware store, and you can find appropriate thickness rubber patches in old bike tubes, or something similar. (I'm sure you could probably skin graft from another Pleo if you really wanted, but thats a little drastic).
Let us know how it works out.
Esta resposta foi útil?
Pontuação 2
Please go to http://BobthePleo.com. A number of people have fixed both necks and tails and can provide instructions and how to locate replacement cable.
Pontuação 2
This is an undocumented field! I haven't heard of any Pleo repairs yet, although I expect it will be more important going forward.
Pleo is quite complex internally. The neck is a delicate mechanism, and I'm not surprised it broke eventually. The only way inside is to completely remove Pleo's skin. Once you remove the skin, you can't really put it back on. So if you were to disassemble and fix the problem, you would have a naked Pleo. Which might be quite cool!
If you're motivated, cut it open and post some photos of the broken neck. We'll see if we can suggest any tips.
Update
I mistakenly thought he had a broken neck. It turns out the issue is with the a split in the skin, so Brett's answer is better.
Pontuação 1
This sounds like a manufacturing defect. I would return it or contact the manufacturer for a replacement. Contact them here: http://www.pleoworld.com/Inquiries.aspx
Pontuação 0
1 comentário:
I've email pleoworld and asked for repair instructions and also how to fix the skin. We'll see if they come back with anything.
por
Adicionar a sua resposta
gillian será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 3,959
